93-97 Head unit install
1. hey everyone with after market headunit on there first generation GS how did you put the after market headunit on the stock bracket. right now i'm doing it ghetto style and only have screws on one side of the headunits holding it up. it seems like the screws on both sides don't line up with each other???
2. also how did everyone wire there antenna to go up and down. i can't figure out how to do it there is like 3 antenna wires in the wire diagram.
3. also last question. how much did you all pay for the plastic piece that goes around the headunit. i know they dont make ones for lexus and i have to get a custom made one but what is the price range. thanks all
hey man, good luck with your install. I use to be an installer myself so i'm doing my own car. I have the Kenwood DVD Player but i'm redoing my dash kit with fiberglass. It's really easy to do it yourself if you want to make a basic kit for your lexus. You can make one of abs plastic if you want to go the cheap way. If you are going to have someone do if for you make sure you get at least 3 different quotes from stereo shops and go with the better deal. As fas as the antenna is concerned, I'm not using it right now cause i'm changing the factory power antenna for a custom mount one. And no aftermarket radio matches up to the factory bracket that I know of. The only kit available right now is for the older ES300.
Good luck,
alex
Good luck,
alex
RanGer498
06-20-06 02:23 PM
e-man
10-11-04 08:04 AM
