93-97 yellow headlight lens (housing)
ok how the heck do i clean my headlights. i tried using this white/blue bottle of plexiglass cleaner from pep boys and it seemed to cleaned the headlights a little but there is a still a yellow hue to it. how do i make my headlight housing lens whiter.???
Take some rubbing compound and rub out the entire headlight...then use some wax to polish it up...what you have to do is rub away a "layer" of the headlight cover...
Other people have used fine sandpaper also...depending on how bad your lights are, you may need to go this route...also, if you use any kind of power tools (buffer or sander), be VERY, VERY careful. It's easy to overdo (or melt) it with power tools...
lowkeySC
Automotive Care & Detailing
17
06-11-09 05:35 AM
