Rear light out indicator on dash problem
if all else fails! do what i did! run around your car throwing Holy-Water on it! seems to work for me! J/k
But for real i ended up Bypassing it http://http://bananags.grantham-inte...le_brake_warn/ its a good step by step by BananaGs, sure you'll never know in the future if your lights go out but hell its better than that bright Orange light on your dash I ended up replacing all my rear lights with LED and was too lazy to go and buy the resistor for the LEDS like GS 4 fiend suggested , ( not saying your advise wasn't good ) im just lazy! after opening the housing and third brake lights numerous times u get tired of it ... Nip/Tuck! works great
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
keep in mind, aftermarket bulbs will sometimes cause a tail light indicator even if the bulb works properly. Always go with OEM bulbs....sounds crazy but I have seen it a million times. Usually there is an aftermarket bulb in the 3rd brake light housing causing this problem.
watts but output is a respectable 180 lumens. The factory bulb pulls 25 watts.
Does the indicator engage as soon as your parking lights turn on or when you hit the brake?
Also, can someone with all OEM bulbs unplug the 3rd harness and relay if that triggers the light out light?
might help if you linked who you were talking to.... i assume its the one below
if so here it is http://bananags.grantham-internation..._DIY/3rdbrake/
and banana's homepage
http://bananags.grantham-international.com/
But for real i ended up Bypassing it http://http://bananags.grantham-inte...le_brake_warn/ its a good step by step by BananaGs, sure you'll never know in the future if your lights go out but hell its better than that bright Orange light on your dash I ended up replacing all my rear lights with LED and was too lazy to go and buy the resistor for the LEDS like GS 4 fiend suggested , ( not saying your advise wasn't good ) im just lazy! after opening the housing and third brake lights numerous times u get tired of it ... Nip/Tuck! works great![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Mines too. Mu brake light is on but I switched to led. The strobe ones. N I trying to figure out wat wires I need to tap I to to get it resolved. I also have a hyper flash but my bulbs r stock. Any help ?
nickels626
16
03-01-11 11:54 AM
Bumbobee
06-24-09 05:31 PM
