Yes another ticket... clear rear signal?
It reads "SMC 11.82.380 : Lights, Turn Signal, Defective"
I have the LED tail lights with the clear lens. When I bought the damn things I just went to schucks and got a bulb.
I guess they can be anywhere from RED to AMBER...
$124 later and a "TRAFFIC" violation to up my insurance.
Seattle Municipal Code
Information retrieved June 25, 2009 12:47 PM
Title 11 - VEHICLES AND TRAFFIC
Subtitle I Traffic Code
Part 8 Equipment Regulations
Chapter 11.82 - Vehicle Lighting Equipment
SMC 11.82.380 Electric turn signals.
Any vehicle may be equipped and when required under Section 11.82.420shall be equipped with electric turn signals which shall indicate an
intention to turn by flashing lights showing to the front and rear of
a vehicle or on a combination of vehicles on the side of the vehicle
or combination toward which the turn is to be made. The lamps showing
to the front shall be mounted on the same level and as widely spaced
laterally as practicable and, when signaling, shall emit amber light:
Provided, that on any vehicle manufactured prior to January 1, 1969,
the lamps showing to the front may emit white or amber light, or any
shade of color between white and amber. The lamp showing to the rear
shall be mounted on the same level and as widely spaced laterally as
practicable, and, when signaling, shall emit a red or amber light, or
any shade of color between red and amber. Turn signal lamps shall be
visible from a distance of not less than five hundred feet (500') to
the front and rear in normal sunlight. Turn signal lamps may, but need
not be, incorporated in other lamps on the vehicle. (RCW 46.37.200(2))
(Ord. 108200 Section 2(11.82.380), 1979.)
donno how close the rules are here up in BC compared to WA, but my understanding is, you can have clear rear turn signals, but they must produce red or amber light. thus meaning u can have it clear, but the bulb inside must be amber or red.
the fronts can be either amber or clear light.
visible from the rear or the side must be a 3in length reflector that is red.
visible from the front side must be a 3in length reflector that is amber.
if ur in taiwan, u can have rainbow lights and they dont care =P
iModerate
If you got amber or red it sounds like you have a case - take it to court. Lots of cars have OE clear turn signals with amber or red turn signals. just curious, are your tail lights marked "DOT Approved" ?
I wasn't thinking, and it was my fault for not knowing.
I replaced my taillights with the AMBER LENS/CLEAR BULB combo with the CLEAR LENS taillights.. and just used the same bulbs. Honestly.. had I known or thought about it I would have gotten the amber or red ones.. that doesnt matter to me.
I'm going to schucks after work to get the amber bulbs.
I'd prefer to get a red bulb but schucks doesnt have it.
I think the bulb number is "7440" but I can't seem to find any red ones online.
http://www.andysautosport.com/gmc/19...r00004626.html
x 2 = $35 + shipping.. eww
*edit: would LEDs work?
http://superbrightleds.com/tail-brake-turn.html
Theres some 7440's there
YODAONE
02-10-18 04:05 PM
