Apexi V-afc work for our vvti?
Old 06-26-09, 09:45 PM
Frankdorn
Frankdorn's Avatar
Default Apexi V-afc work for our vvti?
A local guy wants $100 for his Apex'i V-AFC which controls VTEC, but he had it hooked up to an Eclipse. Would this work on our VVTi?
Old 06-26-09, 10:11 PM
JeffTsai
JeffTsai's Avatar
No, it won't work. VVTi is different from VTEC. VTEC is simply an on/off switch that kicks the camshaft over to a different set of lobe profile. Usually 2 sets of lobes, one for low-mid range power and a second set for top end power. VVTi is a variable system with only 1 set of cam lobe profiles, but the camshaft rotates to change valve timing/phasing. The new Honda i-VTEC system is a variable system more similar to Toyota's VVTi.
There are only two piggyback sysetms I can recall off the top of my head that will work with VVTi. There's the HKS Camcon and Greddy V-Manage.
Old 06-26-09, 11:10 PM
SoCal Cyco
SoCal Cyco's Avatar
wont the vafc control the air fuel mixture and there for able to do somesort of tuning? like cant you say get a intake and them use the vafc to tune it like the srt piggyback for thier intake?
Old 06-27-09, 05:45 AM
JeffTsai
JeffTsai's Avatar
Yes you can use it as an MAF signal modifier or as apexi calls it, Air Fuel Controller. However, he wanted to use it to control the VVTi which the VAFC won't do.
Old 06-27-09, 10:04 AM
Frankdorn
Frankdorn's Avatar
I guess I was thinking that's all it did was control variable valve timing... It could function as an SAFC, too?
Old 06-27-09, 03:27 PM
99Aristo
99Aristo's Avatar
As JeffTsai said, Honda vtec works different that VVTi. Vtec is a soild camshaft and is shiffted with fluid pressure. VVTi has a two piece camshaft...quite a brilliant design that many manufacturers are adopting. so they are different and the SAFC won't work.
99SC42
Performance
13
04-22-13 05:28 PM
Chops@MVP
Club Lexus Vendor Marketplace
18
05-31-11 12:07 PM
tom steele
Performance
01-27-11 06:13 PM
swat1727
12-17-07 10:59 AM
Quick Reply: Apexi V-afc work for our vvti?
