To any/all RE AUDIO XXX owners......
#136
like the stinger one, know where i can get it? im assuming it mounts the terminals on the underside? where can i get either actually.
SOOOOOOOOOOOOOO does anyone know where the positive terminal on the alt is? i dont wanna get back under there yet...and do i need a fuse between this?
#137
as for fusing the wire from battery to alternator, dont think you have to, dont even think its recommended. The factory one doesnt have it fused
Boot on:
![](http://i21.photobucket.com/albums/b279/MRJOKSTER/DSC00242.jpg)
Boot off:
![](http://i21.photobucket.com/albums/b279/MRJOKSTER/DSC00243.jpg)
#138
Darvex.com is the cheapest place to get them, he also has an Ebay account under "bag-boy" I'm yet to find anyone cheaper. and yea, they go on the underside. Kind of a bich to install on there, but look clean as you can see. You will also have to drill the hole a bit bigger on the ring terminals cause the bolts are a bit bigger on the terminal.
as for where its at, its the one with a rubber boot over it:
Boot on:
Boot off:
Boot on:
Boot off:
so now im really confused, 2 people saying to do so and your saying not to...
#139
well it doesnt hurt to do at all, but a ton of wasted money IMO. I've done the big three on all my cars never had problems and didnt have them fused. IMO, its just a precaution. You will have to buy a fuse holder for each side ($10-20 each) and fuses for each side (about $5-10 each) if they dont come with them. Now its not like you're running in the bass olympics, so you're not pulling a ton of power that will over load 0gauge wire which can handle a lot of current.
#142
http://stores.ebay.com/Bag-Boy-Home-...r-Audio-Wiring
but i cannot find a holder like the ones u showed me a minute ago... did u get the one YOUR using from him?
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
i am a better safe than sorry guy. any idea what size fuse i will need?
#143
i tried dudes ebay page
#144
Just message him through ebay and tell him what you want and he will add the item to his ebay store. I bought a TON of ish from him and he told me to make a list of what I need that wasnt there and he added them to his 'store' . Just say you need the Stinger HPM Ring Battery Terminal SPT53R and a link with that picture to seal it off for him ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
well actually i will have a 320 amp alternator....eventually....so i guess i will just get a 300 amp fuse. sorry guys bare with me as i said before i m taking this project more heads on, typically i would just drop it off and say do this and be done with it
#145
updates to come...,i just finished working on the car. im tired.
car goes into shop mon. although still having issues with getting in contact with iraggi....it reminds me of how you'll talk bout TM engineering (who i actually have had good service from)
#146
Brian, for your ground, try something like this;
http://www.hifisoundconnection.com/S...id/0/SFV/30046
#147
![](http://www.darvex.com/mm5/graphics/00000001/SPT53103.jpg)
from jokersters guy on ebay.
well audio shop is backed up till wed/thurs which sucks as i took off m-thurs to give them plenty of time to work on it. ugh...oh well i guess i will break out the jeep or the truck for the next week or so.
gives me a chance to get alternator in before then too. thats the last part....
i will make a complete final list before it goes off to be installed. its fixing to be loud...
EDIT: i just thought bout this....after looking at this pic....these are gonna be annoying if i have to take them off a few times unless they have a hidden screw for the terminal post i dont see??? maybe i will flip them upside down.
#148
#149
Yup, if you look back, I said that they were a bich to install, but look nice
The screw for the terminal facing the back side and is an allan wrench. If you ordered the right one, the screw will be on the outside of the battery, so it wont be to hard to do. I've had to take mine off a few times and they come off ok once you get used to them.
u get my PM bout setting up a page for that?
anyways the 2nd to last part i need to order is a half din dvd player....a external one, not a radio with a dvd player, JUST a dvd player. i was gonna get the audiovox but im having a hard time finding them as it seems they discontinued so anyone know of another HALF DIN DVD PLAYER...not needing anything fancy but dont want some garbage...oh and kinda wanting to order before fri so let me know guys. i got on ebay but most of those look like junk to me
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#150
I've got Stinger terminals similar to the top ones you posted earlier and they tighten with an Allen screw, sounds like the ones you ordered should be similar, not too bad once you get used to it.
Brian, have you run the 0 gauge to the trunk yet? I've gotta do that in the next couple days; debating whether I should try to shove it through that grommet behind the battery or just run it in a conduit under the car.
