VSC - Code 43 - 2 Bad Sensors?
Hey Guys,
I got a quick question, I picked up a 98 gs300 that has the vsc and abs light on, I checked the codes and the abs light does not blink but... the VSC light did the 4 then 3 - I checked the resistance on both front speed sensors and they both say zero, I checked the resistance of the fuel injector to make sure and it showed 14.X, so the thing is reading correctly. I cut both of them apart and the wires look fine, to make sure, I cut the wire right by the sensor and tested resistance right on the sensor, still nothing!
My next question, is it common to have both speed sensors go bad? Where is the best place to buy 2 new speed sensors? I know these things are pretty expensive, I think around $200.00ea?
Thanks for your help!
Michael
Michael
jrmyrnsm
GX - 1st Gen (2003-2009)
06-29-19 05:03 PM
