New Pictures Of GS - RSM and Momo included
#31
Sasha - how did you get the wire from the Apexi RSM to the ECU? And they have hook-up info for a GS specifically?
And you can close the ashtray with it in there?
Way cool.
Only thing I'd be concerned is looking at it down there and driving off the road!
Way cool.
#33
Originally posted by LexusRules
no direct hook up... u have to wire it into the ECU yourself simaler to the S-AFC but not as many wires
Either way, how'd you get a wire from the Apexi to wherever you soldered it into the ECU.
#34
it has a wire coming out of the right side of the RSM which goes all the way to the ECU, under the dash and through the firewall into the ECU. I didn't do it the shop did, but thats how they usually do it.
the wires are on the end and then tap into the ECU and record signals. then the g-sensor goes through and plugs into the bottom of the RSM. it gets power from the RSM
#35
Thanks Sasha. Cool that the shop can do this for you! Not sure I'd want to tackle that myself.
#36
Another try...
#37
yup check it out, closes like stock
although takes much more force to close it since they had to cut off some of the conntecting part.... but it still closes
edinburger
09-03-09 12:53 AM
