Tire sidewall hieght
i just went through this same dilema. i have 20x8.5 front and 20x10 rear with roughly the same offsets. i had the 255/35 and 275/30. did not like the way they looked also. i kept the fronts and got a 275/35 rear and LOVE the way it looks now. i could use a 10mm spacer though. i am lowered on tanabe df's. but i do have my front and rear fenders rolled though. the set up you are talking about (245 & 275) are considered the fat tire set up. good luck with what ever you do but if all you need is a little fender mod DO it
and remember the more traction (tire) the better
The difference between your front and rears was probably closer to 3/4-1" overall difference.
If mine was that bad, yes, I would switch them out too. But I'll throw them on and I'm sure they'll be fine. Thanks for your input!
