so my SC pulley bolt came loose..
If it's not already labeled call up RMM. If they don't know/won't give you the bolt size/pitch then just find out who makes the supercharger (vortech, pro-charger etc..) and the model number. Then call the manufacturer and get the info, you should be able to get the bolt from them or from your local Fastenal, McMaster-Carr etc...
http://www.vortechsuperchargers.com/...on.php?pvk=412
i think thats what i need ^^^
schase: ill try getting more pics when im not to lazy lol
so i jacked up the car n checked the undertray thing... the bolt + washer is no where to be found... sigh..
is it ok to drive without the SC belt?? i was able to drive from OC to riverside fine.. as long i didnt hit the boost rpm range. but can someone confirm?
The link you posted looks like it could be correct. make sure you don't lose the key that aligns and locks the pulley on the shaft, it will a little piece of metal, most likely a half moon shape. You can do some research with Vortech and try to get the size and pitch etc..of the bolt then check out your local industrial stores as I mentioned before. if you don't want to do that just order it from Vortech, in the meantime I personally wouldn't drive it but it's up to you, if you choose to drive it make sure you remove the pulley and key and the belt so nothing gets damaged.
yea the key is a box shape thing. i removed the pulley and the belt already so i think im good.
hopefully ill try to figure something out tomm... on the bright side.. i just installed my Brembo blanks + Endless brake pads
