NF210 & eibach pro kit , 18" wheel
For some of the people that want to slam their rides the emphasis seems more "show than go," for the individual who started the post he's looking for more functionality than fashion so I don't recall equal finder gaps being an issue for the poster.
My suggestion is that the poster contact the spring maker to clarify the difference between the 430/400/ and 300 spring drops. I imagine since the curb weight of each of the vehicles is about the same there most likely won't be a problem interchanging applications.
i'll try to snap some pics in a few, started to rain in ny.
you have a point there with the balane/weight, our heavy 8/6 engines would cause a problem if it dipped in sudden braking or any hard cornering. but since we have progressive springs should it still sit that way? i would think a more aggressive single rate spring would do that only. im not too familiar with suspension yet, only use i have them for is a more steady ride never pushed em to the test theyre really made for.
you will definitely feel a difference compared to stock, especially since i went from my oem 16's to 18's you feel the road now. when you go in and out of lanes the car feels more confident at semi high speeds (75-90) and body roll is reduced by alot for normal highway roads.
only thing to me is i have a tte lip and ny has alot of steep driveways for everything here malls/supermarkets etc.. so i have to be careful how i exit/enter areas now even with a 1'0 drop i scrape around here. if anything i would have gone a slightly fatter tire setup just to give me that added small protection from nyc potholes and stuff.
