Headlights Faded?..I have the cure!
I have read from past threads that many of you have been experienceing the problem of your headlights fading over time. This causes your lights to be dim, and your car to look old from a frontal view right? Have any of you priced new headlights ... around $500 each for first gen and $75-$250 used. i read where one guy took lights off tried to open them---They are sealed shut , plus its a lot of trouble to take them off.
Well, it looks like there is residue on the inside, there really isn't, we'll it's minimal. The fading comes from oxidation from the sun and outside elements and and possibly cleaning materials that you use on your car.
Here's the cure---I have been detailing cars for about 14yrs. All you need to do is when you are buffing your car (waxing). When using a professional buffer not an oribatial (RPM won't be high enough) Buff the headlights as well, you won't need to add any wax to the lenses the residual on the medium density pad should be enough. But if yo u like you can it won't hurt the lense. You will need to use a high quality wax made for buffing / these generally have a cleaning property (similar to a rubbing compound but not as harsh0 coupled with a waxing property (which gives UV protection and luster). This procedure should only take under a min. for each light. They are plastic and can be polished just as silver, gold , glass and aluminum can. Your foglights on the other hand cannot you will need to replace them . If you guys don't have the equipment go to a detail shop in your area and they should be able to do it --don't pay much this is really simple and don't use a rubbing compound (too harsh may scratch lenses) They will look like new when you are finished .
Hope this helps
Hope this helps
Hope this helps
Hope this helps
I have done this before at a auto body shop. It gets most of the stuff out, but it does NOT look like new when done. It looks better, but not like a BRAND new headlight assembly.
My dealer just replaced mine because of condensation build up, and non-hid and hid lenses only cost about $450/pair (that's what the price list said), so I guarentee that they could be had for less somewhere else.
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
Guyz - How come when I said I used the fine Griot's polish & the Porter Cable buffer to do the same thing almost a year ago ya'll laughed at ME!!:eek: Guess I'll just go back to my Electronics Forum where I belong, huh?!
BTW - It's an improvement but, like Manuel said, it's not quite as good as new. Of course, I'm not a professional detailer like 007 so I'm sure there's some operator error involved!!
Also 1st gen parts seem to be a lot more than newer models
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
MT - OUCH!! I thought that only applied to my driving!?:eek: I'll be over in the Electronics area from now on - U guyz play MEAN ( oops, my screen name!
) over here!!!!!!!!!!!
007,
Thanks a lot, man. It worked out great for me. I just replaced one of my headlights because of the condensation build-up. And ever since I did that, my car looked funny. I had one new head light and one old. But now, man oh man. My baby looks great, both of the headlights look practically the same even when you look close. That was a great suggestion.
Regards.
Keep it Lexus. Yeah, baby.
Regards.
