Electric Nightmare.. Any ideas???
On a sidenote My battery was jumped the wrong way, funny mistkae by a fellow CL member. I fired everything it seems. Lost power EVERYTHING. alarms went off horns went off. ANyways its one of the master 120amp fuses that was my problem. Its around $24 and is located on the fuse box in front of the battery. It's a ***** to get to, you have to comepletely unbolt the fuse box. The fuse is actually held in by two bolts too. Anywyas, I think you jumped your car wrong.
Some alarms are smart enough to know not to go off when you reconnect the battery. What you can try doing is leaving the key turned to the ignition on position before reconnecting the battery. Depending on who manufactures your alarm, that may work. Turn everything else off in the car though - lights, radio, climate control... then just leave your ignition on.
If you have a panic switch for your alarm, try turning the ignition on, then pressing the panic button. That may put your alarm into valet mode and it shouldn't go off after that. Or turn ignition on then off then press the button. Some combination of turning the ignition on/off and pressing and or holding the button, should turn the alarm off. Be careful though because this is also how you access advanced programming options on some alarms.
If you have a DEI / Viper alarm, you can put it into valet mode by pressing 1, then 2, then 1 again. The flashing LED should go steady if you do it properly. hold each button for 1/2 a second.
Did you do any work to your car recently? Pull any panels off? There are dozens of factory ground locations in your car (usually ring terminals held on by 10MM bolts). If one of those grounds were accidentally removed, it can cause problems similar to what your mentioning.
Try all the basic stuff first before you go for high dollar parts like ECU's because usually the fusible link (master fuse) to the car will blow before any damage can be done to ECU's.
Good luck and may the force be with you...
