Warranty question for my GS
I need to get my headlight fixed at a Lexus dealership. Now I'm still under warranty so do I need a piece of paper saying that I have a warranty, or do they just run the VIN number and see.
Also will they fix the bulb since it blew out? And I also have some condesnsation in my other lights, will they fix that?
If your lights bulbs/HID are stock then they will replace under warranty. They will run your VIN # or last name to see if you have warranty left on the car. They should also fix the condensation build up in your lights as long as nothing has been tampered with. While you are there, you should have any other minor issues fixed.
Listen when u take ur car in, if they fix it, they are more then likely gonna ur car to a body shop to get it fixed, Be very careful and make sure u keep an eye on ur tires before u send it to them, because I had a problem one time, not gonna say where cuz it was all fixed now, but my back wheel wells had burnt tire chips all inside the wheel well after i got my car back... so good luck
ShOwGS
ShOwGS
Originally posted by JAC JZS
future, where are you taking your car to JM Lexus? If you are they are awesome I have been going to them for years.
futuregs, first off JM Lexus is very reliable and the service is great. They are located about 10 minutes from us on Sample road just a little bit west of the Turnpike. They are also the closest Lexus dealership to us. Go there and you will see what I am talking about. Last time I was there they had a nice modded/L-Tuned GS430 on the lot. They wanted me to take it out for a test drive but I didn't have time. They claim the car had 360 hp but I am thinking more along the lines of 340hp by looking at the list of mods it had done to it. Check the place out. BTW you go to Lynn right? I dated a girl a couple of years ago that went to Lynn, good school
JAC
JAC
JAC
JAC
Anyway, thanks for the info I'm stopping there Monday.
warranty
Futuregs, they can pull up all that info on the computer and should solve that condensation problem for you, if they don't read my post "Faded Headlights? .. I have the cure"... use that for the future as well. Good luck and try to get everything under warranty that you can, everything, i had my rear speaker replaced after my sister turned the radio up too loud with bass up all the way, (didnt tell them that though)
