VAIS Install Help
To take out the OEM radio you pull out the top ac vent/clock, Just grab the vent tbas and pull. Then put the car in N and pull out the ashtray, also held in by clips. Then you will be exposed to 4 10mm bolts, two top, two bottom. Unscrew and the OEM radio will come out
rharse
08-02-08 05:41 AM
