a/c compressor replaced, makes gurgling sound when turning off car
Hey guys. My compressor went bad a few weeks ago, so I bought a used one off a CL member and had it installed last week. It blows ice cold, but I noticed that when I turn off the car, I hear a low-pitched gurgling noise from the vents. I also sometimes hear what could best be described as a start up noise coming from the vents when I start the car. I know this isn't normal, but it only makes these noises on starting and turning off the car. Is this anything to be concerned about? Thanks for any help.
e
e
1 Post
e
e
e
If you heare gurgling, I suspect you are low on coolant and/or go some air in the cooling system. There is a thread about this. Check the coolant when the car is cool and open the radiator cap and see if it's low, then add. Then turn on the heater so you can get the air out from the heater core.
jwadhwa
RX - 1st Gen (1999-2003)
01-13-11 01:21 PM
