I cant find anyone thats done this, Anyone have or know if 20x10 will fit up front? well actually all around lol........ -13 offset
There going to stick out past the fenders is what im thinking..
Any help?
not lowered right now but probably picking up some springs that go 2 inches front and rear eventually..
yeah, i wouldn't do that if you are only planning to run springs. Most members would be scared to run that in the rear, let alone the front. I would pass on those man.
you are forgetting the fact that you will need to chop up the fender as well. and the front will look like it's wider than the rear, so you will probably have to run spacers in the rear as well.
You can only fit these if you do fender work. It will surely look very weird if you do this and you're only running lowering springs. I'd consider doing at least a coilover setup.
