Sealed or Ported box sounds better in a 2GS???
Im boutta buy my friends two 10s JL w6 in a ported box with an diamond audio amp... sound koo in his tacoma but i wonder how it was sound in my car.. boutta buy some wires and junk later but just curious about the box.. any1 wanna chime in that has a ported or sealed box in the trunk ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
thanks
thanks
I was always under the immpresion that a trunk would require a sealed box, and something like a tacoma, suv or hatch would need a ported box...? maybe im wrong, but hey who cares if its a good deal just buy it, plug and play , you can always get a sealed box later... however i would recomend going CUSTOM! sounds hella better!
different style boxes product different sounds. it really depends on what kind of music you "thump" to.
i listen to hip-hop/rap/pop/etc and i like to be able to hear all my mids/highs/lows. Therefore my bass signals must be "clean" and not overwhelming. im not like some people who try to rattle all the nuts and bolts off my car.so If my amp as plenty of power to push my subs, i'd go with a Sealed box.
In your case, i suggest you go with a sealed box. JL and Diamond audio strive at Sound Quality; therefore a sealed box would help produce the best SQ. plus, if you wanna "thump" the hell out of your brains........... trust me, you'll be able to if you can get the proper amount of power to those W6's.
What you could look into doing later is running a port from your box up to where the stock sub was in the back baffel board, so the bass thumps are dumped in the inside of the car which = louder bass like trucks. Trucks are loud cause they have the cab of the truck, which acts like a trunk, we have a trunk that separates the SPL's from the woofers and the passengers. So Really you want loud heart thumping bass go with a ported box but then you better dynamt the **** out of your trunk to eliminate the rattle. but if you hard hitting but solid bass then go with a sealed box. Oh yeah if you get a sealed box it also wears the life of the woofer down faster than a ported box. The air has nowhere to go in a sealed box so thats alot of stress on a woofer.
I tried both many times, ended up with a Sealed box for my Hertx 8" in the factory location in the boot (trunk) and bolted under the Parcel Shelf. Sealed with the 'face' of the sub facing upto the rear glass ftw imo.
The bottom line: there is a reason why most amateurs who do not have access to the software and design tools should simply run a sealed box. If you want to run a vented custom enclosure, I would highly recommend contacting the manufacturer and build it to the specs for the exact woofer you have. Many of them will give you the numbers and specifications for free. Then, it's as simple as building it correctly.
Big Mack
I don't know the specs on the JL W6. Some subs require ported and some sealed, or some u can use either. I'm running a single 12" Fosgate T112D4 in a custom ported box that sits up on that lil "shelf" in the trunk(this is a 2.5cu ft box for 1 sub!). I usually run 10's in either a sealed or bandpass but this hits hard and clean.
