KiPod's GS Pic & Mod thread
Old 05-29-14, 03:17 PM
  #166
99GS400HP
99GS400HP's Avatar
Originally Posted by Cbrmaniak
Move e7 25 to e5 7. No soldering. Keeps it factory looking.
so i just move and replace correct
Old 05-30-14, 03:34 AM
  #167
Cbrmaniak
Cbrmaniak's Avatar
Yes that is correct
Old 10-31-15, 03:57 AM
  #168
angus
angus's Avatar
Bumping this thread because I would like to know if anyone else on here has GTE swapped their 400?
Old 10-31-15, 01:06 PM
  #169
clos430
clos430's Avatar
Doesn't get better than this one!
https://www.clublexus.com/forums/lex...ilt-right.html
Old 10-31-15, 08:17 PM
  #170
SoCal Cyco
SoCal Cyco's Avatar
Originally Posted by clos430
love that car
Old 01-11-18, 07:00 PM
  #171
Dvemon
Dvemon's Avatar
Do you have the diagram for the shift lock ??
Old 01-23-18, 04:24 AM
  #172
KiPod
KiPod's Avatar
Electrical? See attached.
File Type: pdf
Old 01-24-18, 06:51 PM
  #173
burteboy
burteboy's Avatar
Default trd cluster
where did u buy the trd cluster.
Old 01-25-18, 06:21 AM
  #174
KiPod
KiPod's Avatar
I believe it was on eBay.
I've seen them a few times.
Old 01-25-18, 07:30 AM
  #175
SoCal Cyco
SoCal Cyco's Avatar
they are crazy expensive
Old 04-06-18, 01:39 PM
  #176
Dvemon
Dvemon's Avatar
I did the same swap on my gs400, I followed your wiring diagram, I’m having a limp mode issue,
throttle control motor circuit malfunction.
ive replaced the motor numerous times, replaced tps and apps,
mans I was wondering if you ran into the same issue ? I’ve ran it down to the wiring. And everything matches up to the way you did yours,
my a/c dosnt work either.
Can you please help ?
Old 04-07-18, 11:04 AM
  #177
KiPod
KiPod's Avatar
Sorry, I never had any of those issues.
I do remember there was a junction block where a bunch of power (or ground, I can't remember) wires came together and you had to reposition a jumper to get something to work.
Maybe that was for shift lock, but I don't remember.
I found the info on that jumper in a thread on this forum though so if you search on old Aristo swap threads, I'm sure it's somewhere in there.
Old 04-07-18, 01:24 PM
  #178
Dvemon
Dvemon's Avatar
Damn. Okay thank you.
Old 06-16-18, 08:38 PM
  #179
jeffy
jeffy's Avatar
dope thread, had to get in to save for future gs400 2j swap goodness
Old 09-13-18, 12:25 PM
  #180
F1GS
F1GS's Avatar
Originally Posted by KiPod
Okay, here is the info for what ECU pins I moved for the swap. If the pins were in the same spot I left them alone & will skip them on the list. I only listed the wires that need to be moved to a different location or removed from the connector. I will list the connector w/ pin where it was for the 98 GS400 then where it needs to be for the Aristo.
Connectors E2, E3, & E4 run from the engine to the ECU so they should all be in the correct place alreay (if your swap came with ECU & harness together). Connectors E5, E6, & E7 are from the vehicle body to the ECU so these need to be moved to match the new ECU. On my Aristo ECU there was no slot for the E7 connector so I listed those as "remove" as well.
If I say "remove" it's because it is either already in the correct location on the Aristo harness (in connector E2, E3, or E4) or you don't need this wire. You should remove it from the connector and tape it off. The list should read like this,
98 GS400 location (Wire Color) - Aristo location
So, you would move pin 2 on connector E5 on the GS400 harness (Red wire with Black stripe) to pin 16 on connector E5 for the Aristo ECU.
E5 pin 2 (RED/black) - E5 pin 16
E5 pin 3 (GREEN/black) - remove
E5 pin 4 (GREEN) - remove
E5 pin 7 (GREY/black) - remove
E5 pin 8 (GREY) - remove
E5 pin 10 (WHITE/red) - remove
E5 pin 15 (RED/white) - E5 pin 26
E5 pin 16 (BLACK/yellow) - connect to ignitor for tach signal (you will need a tach adapter to get it to work with a 400 cluster)
E5 pin 17 (BLACK) - E5 pin 2
E5 pin 18 (WHITE) - E5 pin 8
E5 pin 19 (WHITE/green) - remove
E5 pin 20 (GREEN/red) - remove
E5 pin 22 (BLUE/yellow) - E5 pin 18
E5 pin 25 (RED/white) - remove
E5 pin 26 (WHITE/black) - E6 pin 22
E5 pin 27 (RED) - remove
E5 pin 28 (YELLOW/red) - remove
E6 pin 3 (BLUE/black) - E3 pin 8
E6 pin 22 (GREEN/red) - E6 pin 15
If your Aristo ECU is like mine & doesn't have a slot for the E7 connector, you don't have to remove these wires. Since the connector is left hanging loose it will not interfere with anything.
E7 pin 1 (YELLOW/black) - E5 pin 17
E7 pin 2 (BLUE/yellow) - remove
E7 pin 3 (VIOLET or Purple) - remove
E7 pin 4 (WHITE/black) - remove
E7 pin 11 (WHITE) - E5 pin 28
E7 pin 14 (BLACK/blue) - E5 pin 11
E7 pin 15 (RED/green) - remove
E7 pin 16 (RED/yellow) - remove
E7 pin 17 (BLUE/red) - remove
E7 pin 18 (GREEN/black) - remove
E7 pin 19 (BLACK/white) - remove
E7 pin 20 (YELLOW) - remove
E7 pin 21 (GREY) - remove
E7 pin 22 (LIGHT GREEN/red) - E5 pin 10
E7 pin 23 (BLUE/black) - E5 pin 21
E7 pin 24 (BLACK) - E5 pin 27
E7 pin 25 (YELLOW/green) - E5 pin 7
E7 pin 26 (PINK/blue) - E2 pin 26
Sorry, if it's confusing. Sometimes things make sense in my mind but they don't come out as coherent. I think there were 1 or 2 other wires I had to move to get the shift indicator & shift lock to work. I think they were in the grey junction block beside the ECU & next to the orange junction block. I can't remember for sure though. If someone does this and runs into a problem with them I can check to see what mine look like.
Hey i am currently doing a 2jz gte vvti swap to my 98 gs400 and i am in desperate need of your help.the main problem with these posts is you only post wire color, you dont provide a key that says what each wire does in function in correlation to its color and ecu pin. Wondering if I can get in contact with you. Things im having problems with is Hvac controls, E-shift, a few other body functions. Any help or response would be life changing thanks!
Quick Reply: KiPod's GS Pic & Mod thread
