I can't remember for sure but I believe the one with the chip is slightly thicker and has some weight to it. You can always just try to program it. It either will or will not work. No harm in giving it a shot.
You program it the same way you would a key. You can have someone at the dealer do it or you could probably find directions on here somewhere.
no i mean....assuming the key holder i have, has a chip in it. how do i program that chip? when i programmed my key, i had it in the ignition if i recall correctly
Would you just not barrel it with a screw driver and do without it? Up to you but surely its not that important as the boot can't be opened when the car is locked anyway.
no....some of us like to use the functions of our cars sir....
abel....can you chime in on my ? about the wallet key im asking about
congrats emil. i seem to have pilferred your post though
lol,no worries mate,hope you can get your key issue sorted,i'm not to sure on having a current key re-programmed,is there no way to erase the current configuration on it?
