I ran mine underneath the car. Fronts were run through stock holes in the trunk and for the rears I drilled 2 holes at the base of the rear shock towers. Lines have no kinks or weird bends and have had no trouble since I put them in. BTW I am running SMC 3/8 inch line.
Any pics of them mounted inside the ashtray? I'm wondering how am I going to do it to secure there.
all you really got to do is remove ashtray tray, then with a Dremel Tool, cut the back side off that tapers a bit and the digital meter slides in PERFECT! Its amazing how it slides in real snug. Just got to cut the back out so nothing stops it from sliding through. However, be careful. At the bottom of the part you need to cut, theres a little piece there that the cap (wood cover if you have it) clips to, if you cut that part off, then the cover has a hard time staying on, I did that on accident and without a little epoxy, it would just come off everytime I looked at it
theres a write up on here... I'm still looking for it.
