UCA Hole, finally did it.
#47
One from the LS400 section:
https://www.clublexus.com/forums/6332599-post157.html
The hole saws have a pilot drill but an easy approach prior to is to drill the pilot hole first. That way you insure you are in the right spot and the hole saw pilot bit will easily feed on that first hole.
A hole saw like this but this one is for a different material...just so you can see the pilot bit:
#48
nope no need to do this mod, i raised my car up.....LOL dont care about my post count im so over you little fan boys about my post count.i AM smart enough to know how to use a hole saw and that they need a pilot drill bit. you on the other hand cant even figure out how to cut a hole succesfully...hands off to you
#50
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
sakataj, please exit this thread. Please be instructive rather than insulting.
#51
check out this diy, clean and simple. looks oem too.
https://www.clublexus.com/forums/5535772-post16.html
#57
maybe i'm a dumbass.. but i work on cars for a living.. i used the pilot drill and jagged hole saw and that did not work out at all.. I have a snap-on drill and obviously did not work. ended up making a ugly *** rectangle cut with an electric cut off tool (all we had to use at home). so perhaps everyone is using an electric drill or air drill cause the battery gun don't cut it. whatever, no one is gonna see it. i'll eventually get it covered up too
#58
Glad I found this thread. Will be doing this and fabbing a cover to make it look OEM soon. Capping th holes not only looks better, but reinforces the area you cut the material out of.
XenonDepot
Club Lexus Vendor Marketplace
25
05-06-15 02:33 PM
RedPhoenix
Performance & Maintenance
18
11-10-09 08:33 AM
