I need some LSD.....Who has the hook up
Old 04-18-02, 11:53 AM
  #31
///MDex
///MDex's Avatar
Originally posted by LexusRules
Dex yours is torson type right? and the TRD one is clutch type?
Yep
Old 04-18-02, 11:56 AM
  #32
enginyr
Banned
enginyr's Avatar
Originally posted by Dex
Yep
So trd sucks? Rmm rules when it comes to LSD?
Old 04-18-02, 12:09 PM
  #33
///MDex
///MDex's Avatar
No no no. They are actually both Toyota OEM parts, and the Clutch vs Torsen debate can spiral out of control. They each have their own characteristics that different people find attractive.
Me: briefly, I like the taller ring gear for the "hole shot"; I liked the idea of a direct R&R swap for the stock diff; and lastly, no maintenance.
I've only driven mine for a few days so far, so I'll provide more feedback as I get more miles on it, but it was great for those first few days.
Folks who have the TRD Clutch type unit will sing its praises; I'm sure its a top notch unit as well.
Old 04-18-02, 12:29 PM
  #34
wwest
wwest's Avatar
Default VSC
The clutch (wind-up) type LSD cannot ever come into play if the TRAC system is enabled, I don't know if turning off the VSC also turns off TRAC, it certainly doesn't turn off ABS.
Old 04-18-02, 03:52 PM
  #35
Mr Johnson
Mr Johnson's Avatar
Default Re: VSC
Please stop. You clearly don't know what you are talking about on this issue.
Old 04-18-02, 03:56 PM
  #36
enginyr
Banned
enginyr's Avatar
Could you possible describe the difference between LSD in "Lamens" terms.
Old 04-18-02, 04:30 PM
  #37
///MDex
///MDex's Avatar
I'm not a diff wizard or anything, but here are some good article to digest at your leisure.
http://mkiv.virtual.net.nz/techo.htm#TORSEN_VS_TRD_DIFF
This one is especially good.
http://www.howstuffworks.com/differential6.htm
General web searches are also helpful "clutch vs lsd", as well as some of the discussion here "differential", but the two links above should provide you a good foundation, and, the answers aren't coming from me.
Profez Ric
IS - 1st Gen (2001-2005)
09-18-04 08:58 PM
joshlee78
07-28-04 07:13 PM
lexoman
Performance
27
05-16-03 02:33 PM
lex400sc
Performance & Maintenance
28
10-28-02 05:23 PM
Hermosa
SC- 1st Gen (1992-2000)
14
03-31-02 08:41 PM
Quick Reply: I need some LSD.....Who has the hook up
