I need some LSD.....Who has the hook up
Banned
HAHA...Not acid......Limited Slip Differential...
What is the best LSD.
How much do they cost.
Whats average installation cost.
Anyone have a used one or Have whole sale hook ups?
Best LSD
The VERY BEST LSD is the one you already have in your Lexus, it's called TRAC, no mechanical LSD can outperform it!
The very best mechanical LSD can only deliver 6 times the torque delivered to the slipping wheel to the wheel with traction. Think about that, just how much torque does it take to spin a tractionless wheel and then multiply that by 6!
If TRAC is used to BRAKE the slipping wheel then unless the engine is quickly dethrottled the opposite wheel MUST turn else something will break!
Re: Best LSD
There never was, or is there currently, an LSD available from the factory for the US Spec GS.
6 times the total available torque? I don't understand the point you are trying to convey.
You come across as rather knowledgable, so I am very interested in your answers.
wwest - TRAC will stop you from spinning wheels and skidding by SLOWING YOU DOWN. LSD lessens/eliminates spinning wheels WITHOUT SLOWING YOU DOWN. Giant difference.
If you just want to go slow, get a Camry.
Forum Administrator
TRAC
The earlier implementation of TRAC in my 92 LS was the PITS !!
Any drive wheel slippage at all and it would instantly brake BOTH
rear wheels and just as instantly dethrottle the engine.
On my MY2000 GS300 it applies "modulated" (hard, medium, moderate) braking to ONLY the wheel that slips and will not dethrottle the engine unless wheel slippage is repetitive or continuous.
Originally posted by enginyr
ya im real confused...
https://www.clublexus.com/forums/sho...threadid=32338
Sounds like another basis for "what's better" kind of thing. This really makes this board interesting.
Let's settle this early on. Let's get the quarter mile of a GS bone stock and compare it to the same GS with LSD.
I need a bone stock GS to borrow for half a day to test this!
Consider this for a moment... the TRAC system uses sensors to detect wheel spin and then reduces power to correct the problem. Having said that, what would happen if you put a mechanical device on the system whose sole purpose was reducing wheel spin... oh, say maybe an LSD. OK, so now we have a mechanical device in place that reduces wheel spin so that the sensors now have no wheel spin to detect, therefore, TRAC doesn't get kicked on and reduce power.
Get the picture? The LSD certainly will and does have a perfectly good place on our cars... contrary to what others may say
I guess many of us thought this *had* been settled some time ago.
Believe me, I didn't go out and buy a LSD because I already had the "the very best LSD". Folks without a LSD should go drive a car that has one and includes the TRAC on top of it. They would not be arguing the point anymore.
For those of you who still want to argue the point in the extreme cases, where we are talking F1 type environs, I *might* give you the benefit of the doubt wrt software and hardware necessary to make a TRAC-type system work better than a mechanical LSD. But I'm pretty sure even Ferraris 2002 car has a clutch type system in their gearbox that acted, or could act, like a LSD and is therefore questionable in the F1 rulebook.
off-trac(k)
Mumbles:
My GS300 doesn't reduce the engine power to prevent or decrease wheelspin unless it is unsuccessful using the rear brakes for that purpose first.
Banned
I could never under stand why our car just spins the tire that isn't getting traction. It makes more sense to put the power to the wheel with the MOST traction.
There were a couple of times on Sat and Sun where I feel rather sure I'd be in a predicament had I relied on VSC by itself. Just a couple of times though.
For those two days, I never turned off VSC. Now I don't have to look at that VSC OFF button on my dash any more.
