Squeaky Steering Column
Old 04-26-02, 08:40 PM
  #31
gs4to4
gs4to4's Avatar
I got the same problem on my 98 GS 400. For some of you, here's a temporary option: Under the CBEST settings, one of the options allows you to disable the auto wheel lift when you remove the key from the ignition. The dealer should do this for cheap, or even free.
Some other cool CBEST settings (my favorite):
Using the remote, press open door lock 1 time, and all doors will open; Press the trunk open button (you do not need to press and hold for 1 second anymore), and the trunk will open instantly; Adjust how loud you want the "beep" to be when you open or close the car using the remote; All doors lock automatically when car goes into drive and unlock when you go into park. Actually, you can control about 20 more different things with the CBEST. Gotta love Lexus for that.
One thing that really sucks, I haven't figured out a way to disable the following: If you press the "door open" button on the remote, after 30 seconds the car will lock itself again automatically. Easy way to get locked out if your door sensors don't work all the time like mine. I consider all these little glitches very minor problems and they are nothing compared to the usual problems that BMW, Mercedes, Audi, and Cadillac owners face. Those cars are such disasters, that most owners don't even consider what we talk about as problems, they just live with them and worry about bigger things. Isn't it amazing that not even one person in this forum has ever had a major mechanical problem?
Old 04-26-02, 08:43 PM
  #32
enginyr
Banned
enginyr's Avatar
My left HID just went out
Old 04-26-02, 10:42 PM
  #33
redgs4
redgs4's Avatar
I had the main rear engine seal fail within a month of getting my certified GS [42K miles]. Luckily I noticed the strange red goo on the floor of my garage when it was little more than a dribble. The dealership experience was so great [compared to past cars] that I consider the failure a non-issue. Would have been different if it had failed catastrophically.
Old 06-01-02, 06:48 PM
  #34
0110101
0110101's Avatar
Default What works for me
I posted this same subject a year ago. All I can say is that WD40 works for about six months and I have to relube it. Make sure you apply the stuff in the screw looking motor which moves the steering wheel up and down. If anybody knows a better lube, holla back.
-SK-
Old 06-01-02, 11:54 PM
  #35
GSquicksilver
GSquicksilver's Avatar
Anyone ever try bearing grease?
Old 06-02-02, 02:54 AM
  #36
enginyr
Banned
enginyr's Avatar
I did.....DON'T DO IT....Re-read all the posts.
Old 06-03-02, 02:59 PM
  #37
VVT-i
VVT-i's Avatar
Lexus use special kind of grease for the steering column this is the part number 08887-02007. It's light yellow in color in a small plastic bottle ( 50 grams). The retail is $45.00, but don't buy it. Go to Lexus service dept. and go talk to one of the tech and ask him to spare some of the steering column grease. They probably have about 10 or more laying around in the shop.
Old 04-13-04, 06:08 AM
  #38
e1701b
e1701b's Avatar
Default Steering column grease
In the TSIB for the 99 LS400, I saw the part number for the Lexus grease, but if you look next to it there is a reference to another product - Sta-lube p/n SL3174 or equivalent. Sta lube is made by CRC Industries and number 3174 is a CV Joint Grease of Moly and lithium according to their website. Should be available for much less and still fit the Lexus Spec.
Old 04-13-04, 06:22 AM
  #39
e1701b
e1701b's Avatar
Old 04-13-04, 10:13 AM
  #40
koreanpers
koreanpers's Avatar
might as well add my car to this list...
Old 04-13-04, 10:37 AM
  #41
e1701b
e1701b's Avatar
Found the Sta-Lube SL3174 at NAPA for $2.99 per tube.
Old 04-13-04, 12:55 PM
  #42
Bdragon007
Bdragon007's Avatar
thanks for the infos , hopefully this annoying noise will go away
Old 05-09-04, 08:53 PM
  #43
Cadd
Cadd's Avatar
Where exactly do you guys grease up?
Old 05-09-04, 09:25 PM
  #44
RayGS3
RayGS3's Avatar
I recently discovered this problem. I will take it to the dealership and have them fix it.
Old 05-10-04, 04:39 AM
  #45
RanGer498
RanGer498's Avatar
add me to the list ..only happens when my car is very hot inside can some one post where to grease exactly.
please
Quick Reply: Squeaky Steering Column
