need help
need help
hi my cigg lighter and ashtray lighter stoped working it was working on and off before but you had to hit it to make it work i was wondering what the probelm could be and how i could fix this also my vsc light stoped working how hard is it to change
Well the first thing you need to check is the fuse. So open the fuse box and check the fuses for any that are broken. If those are all fine then you have a wiring problem or a short in your wiring harness which would require tracing the wires and finding either the bad or opened wire.
GreenUCF20
12-12-12 06:31 PM
