How does your UAS ride?
Well, I have the UAS kit installed. It rides like crap most of the time. I get ALOT of steering wheel vibration. Even when Im on the freeway, I can feel the tires vibrate like crazy. The only time It rides like a dream, is when Im on a street they just fixed. I dont know what pressure I ride at, as I havent yet purchased a digital controller. All I know is that Im on 20's, falken fk452-35. For the rear I lower it so that the rim is perfectly aligned to the fender, and for the front, I lower it just enough to fit my pinky finger. I am curios to see if thats the way air suspension is, or maybe its something else. I am running stock shocks btw.
Well, mine rides cherry but only one one street that is smooth like glass. Even when doing 60 on the freeway it wobbles alot!. I wonder if anybody hasa smooth ride on the freeway?
The uas kit is not gonna ride like a bellowed bag system. Myself and UAS spoke about the ride and they stated to me (in one of my topics) that their kit was made for performance thus creating the rough ride. These "bagovers" are suppose to be a bit stiffer to enhance handling and reduce float and body roll. also, what makes a huge difference are our small profiled tires. When I put my stockers on, feels like stock
and I wish I could keep them on
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
My UAS rides good I ride on stock struts with 100 PSI in the front bags and 88 PSI in the rear. But my stock struts are on their way out so I will be replacing with KYBs within the next week so that I can get down lower. You are probably riding with your bags improperly inflated.
1 Post
My car rides too smooth and floaty, I will be swapping out the struts for coils soon . My problem is when I ride low I get too much rebound causing me to bottom out , no wobbles here. I think its all in the install , did you change out your strut bushings , did you shorten or remove the bump stops? I heard the car can ride like **** if you dont
just wondering those who said it ride smooth...have you try any other brands?
i rode in one uas with kyb ucf20 installed by the owner...another one uas with tein cs ucf30 that is already height adjusted to its "sweet spot" installed by a well known pro...both is still not as smooth as airrunner on the very same chassis...just wondering
It seems like many of your posts consists of air ride problems.. hehe.
That diy that toeb did was helpful. But , I had some problems when I first did my install. First of all there was no directions, I had leaks, I blew up a set of Kyb struts, my bags rubbed my steering knuckle and nearly created a hole. I was about to sell everything and go coilovers.
If your car shakes @ freeway speeds? Are you running the proper air pressure in your tires? Are wheels and tires balanced? The wobbling may be in the wheel and tire area. The wheel may be warped or a tire may be seperated or bald. Or you've got a suspension component that is loose.
Is your struts blown or leaking? Invest in new struts. It will improve ride quality. I picked Kyb because they cost less and they have a lifetime warranty. I already replaced a whole set under warranty, 100% free.
I also do not have an air controller. I'm probably one of the most primitave guys on this forumn. I use my eyes and a yardstick. I run about an 1" or 1 1/2" higher off the ground(you gotta have some room where your shocks can oscillate move up and down) and my car runs just fine. I plan to get the Easy Street ride controller soon. The ride is a lil' "floaty" but I am an Old man and I like it. It's rides smooth like a Caddy. I'm not a racer or an indy car driver, so there's no need for serious handling.
Currently, my GS runs just fine. It's aligned @ ride height and there's no problems.
Here's my cklist of things to do.
-dig air controller
-flip tires every 3k
-RCA kit front and rear
First off, let me thank everyone for their reply. I havent had a chance to log on so sorry. BAD NEWS for me today
. As I was exiting the freeway, I start feeling my car wobbling like crazy. I flash my hazards and get down to inspect. To my surprise I see my right rear rim ripped off from brake, lug nuts and all. Im not sure what its called, but it ripped the things where you screw the lug nuts on. Luckily for me I only had 4 nuts screwed in, and I put my spare tire and drive home with only 1 lug nut @10mph. Its been about a month since Ive starting to drive this car air. I did not take it to get it aligned, so Im guessing thats the culprit, maybe? I feel frustrated
, and I feel like going stock. Im pretty sure its going to be pricey to replace/fix that part.
. Im going to start a new thread to see If I can get any input on that part
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Hey Envy,
You are not alone.
-dig air controller
-dig air controller
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
This post is supposed to go above the one above
