Anyone adjusted ride height sensor?
Are your headlights out of alignment? IF so I would take that to someone who can correctly set the level by using a optical beam setter or similar machine.
Or are you trying to get more light on the road from oem settings? If so I don't think you can. Better bulbs?
I am trying to get more light on the road. I'm using OSRAM 4300k. Got them less than a year. Before I had Philips 4300k but I think OSRAM is more brighter in comparison. I did adjusted the headlights by turning the screws and using the bubble as a reference. But for some reason why, adjusting them didn't really made a difference. Also, my left headlight is higher than the right. So, I'm planning to adjust the ride height sensor, so I could aim it down a little because it seems high.
i don't think that has to do with the height sensor. Please correct me if I'm wrong, but both headlights would be at the same level with different weight loads. I say this because the height sensors are only on one side on the car. Like a 2 channel system, front and rear height.
I had a similar problem a few times. My driver side (usa) headlight was a bit higher than the passenger side. I turned the car off and started it again and the problem went away. Do both headlights do the self test when you turn them on? I'm talking about the dip down and leveling of the beams.
It's always higher than the right side no matter what. The car is stock. Nothing but me inside. I don't think my lights dip down when turning on, on the "ON" position. Never tried in "Auto" yet. But my lights does adjust on slopes and hill.
How do you reset it anyways?
I don't know how to reset them. Both volumes of the FSM are on my holiday list for myself (and you guys in PDF form ). When you turn your headlights on they should dip down for about 1.5 seconds, then return to normal height.
I'm pretty sure all GS430 got auto-levelers. Since they do have HIDS. But I am going to adjust the ride height sensor and keep you guys posted of the result. I'm just posting to see if anyone has done it yet.
A quick story... I attempted to adjust the vertical and the horizontal from the front for my headlights. I cannot get them to put more light on the road. The horizontal aim is centered. The vertical, I did mess around with it, as I try putting it higher and lower but still no difference. I don't know has the car been into an accident before or not. Although the front bumper is repainted. Could be just because of rock chips who knows. As I searched this forum, no one has this problem like I do. I researched about auto-leveling sensors. And people say it should dip down and fly up when lights are on. I don't on auto mode or on mode. So I tried it and it didn't move at all. So I asked how do you reset them? And no ever answered. So, now here I am thinking I should adjust the ride height sensor, which controls the aim position of the auto levelers. So I will attempt this and share to all since it hasn't been mention yet from what I couldn't find. Thanks for reading.
i actually have the same problem as you....or a similar problem i think
my left one sits lower than my right. my levelers work when i start the car they go up and down and then the right seems to be in the right place but i think left is lower than normal (i think i was told lexus aims the drivers light lower so not to blind incoming traffic)
i been meaning to adjust it but i guess i'll see what happens with yours
