So I had a blow out last night
Old 10-04-09, 10:16 PM
amkread
amkread's Avatar
im going with jrezo and saying that nail was more than likely the cause..
Old 10-04-09, 10:19 PM
ShaneC
ShaneC's Avatar
so much tread left.. such a waste. what is the production date of the tire? might of been a old tire or something.
Old 10-05-09, 03:49 AM
aka paco
aka paco's Avatar
how fast where you going?
looking at the pics you must have been pretty lucky looks like nothing was damaged besides the tire.
Old 10-05-09, 09:04 AM
GS300ToM
GS300ToM's Avatar
Falken 452 FTL........
Old 10-05-09, 09:20 AM
sakataj
sakataj's Avatar
Originally Posted by LEXUS_KID
That suck at least you didn't hurt the paint
or yourself.....or anyone else
Old 10-05-09, 09:45 AM
JDMCelsior
JDMCelsior's Avatar
someone said something about being under inflated...what would be the correct tire preassure for say an 18-245-45 size tire? I have Falken's as well and would hate this to happen at 120 miles per hour. :-/
Glad nothing happen to you or your car bro.
Old 10-05-09, 12:02 PM
aka paco
aka paco's Avatar
Originally Posted by JDMCelsior
someone said something about being under inflated...what would be the correct tire preassure for say an 18-245-45 size tire? .
should be listed on the tire.
Old 10-05-09, 10:04 PM
4uhaterz
4uhaterz's Avatar
I was only doing about 45
Old 10-06-09, 12:18 AM
a#'z
a#'z's Avatar
That really BuNkers, you should get an aligment since your at it.
Old 10-06-09, 08:47 AM
bluelex
bluelex's Avatar
I'm just glad your ok and it wasn't worse.
Old 10-06-09, 09:20 AM
vwynn
vwynn's Avatar
you sure? i believe the tire list the MAX PSI. as for actual PSI for the car.. check your manual..
i believe for 2gs its somewhere around 35-37 PSI.
mines at:
Front 40.5 PSI (40 cuz the tire is slightly overloaded.)
Rear 36 PSI
Old 10-06-09, 12:22 PM
AsGs300
AsGs300's Avatar
well, luckliy your ok so is your car! along with your wheel!
***** happens! its a tire it goes through all kinds of crap on the road, just look at it this way! "nothing worst happened!"
Old 10-07-09, 08:43 PM
toeb
toeb's Avatar
mines at:
Rear 36 PSI
on a 245 45 18 i would run 40 psi front and rear the manual would only list the tire psi for the stock tire size. on low pro file tires the max psi is 44 to 5o psi allways run about 5 to 6 psi lower than the max to allow for the psi to build up in the tire with the heat. when you have a low pro tire the side wall is smaller therefore you run more psi to keep the tire up, to much heat building up in the sidewall can cause failure. that looks like what happend here the tire was low in psi bulit up heat and blew the sidewall. ive seen this happen alot as i have been in the tire biz for quite a few years now. as for falken tires as a brand i do sell them and i run them on my rides. i have never had any problems with them what so ever, and ive got them on 5 different cars.
just my $0.2
Old 10-07-09, 09:15 PM
PushinLEX
PushinLEX's Avatar
glad your okay! the tire can be replaced.
Old 10-08-09, 09:34 AM
raytseng
raytseng's Avatar
If that's a nail there, I think it's possible the sidewall separation happened after the nail just during the time driving to a stop on the flat tire to a safe spot.
bigjez
01-10-19 06:50 PM
ItzFilyO
06-30-16 12:49 PM
February
06-27-15 04:36 PM
leecm
Wheels, Tires & Brakes Forum
07-14-10 04:21 PM
Wierdazndu
05-09-10 03:55 PM
Quick Reply: So I had a blow out last night
