wheel fitament
thinkin aboutgetting some new wheels i want a lil agressive setup a lil fender work is ok found 2 sets ofrims but want to know which size would be better.....1. 19x8 1/2 +18
19x9 1/2 +18
2.19x9 1/2 +38
19x10 1/2 +43
any help would be great thanks !!!!!!!!!!!
19x9 1/2 +18
2.19x9 1/2 +38
19x10 1/2 +43
yep stock will be fine, depends how low you go but most people buy camber kits to get rid of camber not add it. you should get a couple of degrees or more from stock by lowering which is plenty to get these to fit
+18 hasnt anything to do with brake clearance, that has to do with the disk size of the rim. that determines the brake clearance.
but i am quite sure they will cause stock brakes on 2gs are pretty small calipers. i have low disc all round on my Works and they clear easy
