Will Changing the gauge cluster (all 3 of them) change the odometer on the GS?
the question is why do you want to switch over to an 02 cluster?
if all u want to do is switch the cluster bezel, then its really plug n play.
however if u are trying to do what i did, which was to switch the speedo over because you want the KM/H the dominant lettering over the mph, then you have to take part the gauge to the point that u unscrew the speedo gauge itself. this requires you remove the needle, so thus recalibrating it is tricky unless you have something to compare it with (i used my gps)
98-00 differ from 01-05 in its pure electronics.
however, physically, and by pure looks, they are identical.
so to answer, will it fit? yes, but will it work? no.
from my understanding, the 01-05 run on a dual staged airbag system. this triggered the error i got when i plugged in the 01 cluster. also, some hand brake/foot brake/parking brake issue also triggered the hand brake/foot brake/parking brake warning light.
2g4u2c
11-09-04 10:34 AM
