Need help from aristo tt swapers
I need a bit of help from you guys who had done the aristo swap. My setup now is the gte vvti. my one issue with the car is the speedometer is not working and i have vsc and vsc off light's on. i have done numberous research and can not figure out which wire is it from engine harness to inside cluster wire. I noticed there the speed signals from vehicle speed sensor. and then the wheel speed sensor off of the abs and vsv. then there is also the pps, speed sensor; which i noticed goes into the cluster and then into the factory nav. but these sensors or wires have never been tampered with so im only down to the engine wires.
im wondering if you guys can give me a helping hand. Thanks!
vipsoarer
Performance & Maintenance
07-22-18 03:56 PM
nicspits
02-26-12 10:20 PM
tavarish
08-16-08 07:12 PM
