want 18" rims on my 2000 GS300
the 18s fit perfectly (from 3gs). I have a set for sale if you like
https://www.clublexus.com/forums/whe...ith-tires.html
Here r the oem 08/GS350 18" wheels on my 03 Sportdesign. Hope it helps u out! GL http://i657.photobucket.com/albums/u...9Myride032.jpg
Do you have any other pics?? Thanks alot - I have the exact same car so your input is very helpful.
Eric
George
http://i657.photobucket.com/albums/u...6142009005.jpg Before rear!
http://i657.photobucket.com/albums/u...6142009004.jpg Before front!
http://i657.photobucket.com/albums/u...6142009003.jpg Before driverside!
http://i657.photobucket.com/albums/u...6142009002.jpg Before passengerside!
http://i657.photobucket.com/albums/u...6142009006.jpg Before angle shoot!
http://i657.photobucket.com/albums/u...9Myride034.jpg After front!
http://i657.photobucket.com/albums/u...9Myride033.jpg After rear!
http://i657.photobucket.com/albums/u...9Myride035.jpg After passenger angle!
http://i657.photobucket.com/albums/u...9Myride039.jpg After driver angle!
http://i657.photobucket.com/albums/u...9Myride038.jpg After backside passenger angle!
Hope this helps.
hmm that sits alot higher in the front than mine and I have the same setup as you...... heres a bad picture but you get the idea. I doubt I can put 1 finger between fender and top of tire when its pointed straight.
Not a problem! I have some DF210 Tanabe springs & KYB Struts. The ride is very nice I believe that the tires r 245/40/18 Yokahamas. There's about a 2-figure gap in the back and a 2 1/2 figure gap in the front. I don't have any spacers. The back has a small camber issue that has not shown any wear on the tires. I'm pretty much guessing on the tire fender gaps. I'll show u before and after springs & struts pics. GL
George
Hope this helps.
George
Hope this helps.
Eric
