interior led lights
Ill try to get pictures up of what I changed, but over winter im going to try to get my gauges from green to white and also the lights by the tape deck to white. I had no idea v-leds had the t3 bulbs..I guess if these ever go bad ill switch over to theirs and try them out. ^your saying they are brighter than wardens on ebay?
i had a spare nav and i was hoping to change out the bulbs. when i opened mine, i noticed bulbs were soldered so im wondering which bulbs you actually changed. your pics would be great
Did those which im pretty sure are t3's, but I still need to do the four below that which look like this
and here are the other ones
I took out my mirror switch the other day and I noticed that it also has a replaceable bulb which appears to be a t3. Im going to pull my door panels off and see if all the door/window switches have removable bulbs as well.
(they are JDM altezza or is300 license plate lights and come with 3 leds per side, just hope they bright enough for me)
can always order more if needed
think those are t-3 bulbs actually again would need to see the bottom of them
thanks but actually got the idea when i met tony in Atlanta, he has them already
i have gone through 4 different sets and none bright enough for me. so chado (while he's in japan) is picking me up a set. u can probably get him to get you one....he's leaving in a few days
okay i did the radio display and came out real good. now i have a question i tried taking the whole board where the buttons are. but it won't come out. how do i take it out. i already did the screen now all i need to do is the buttons on the radio. thanks...
okay Ive been wondering this for the longest...
I did this on my Old LS and was wondering if the process is as easy on the GS as it was on my LS.... they seem to use the same twist lock bulbs
THIS is the procedure I used... well atleast the bulbs and the type.
http://www.lexls.com/tutorials/light...klighting.html
SOOOO I wanted to know IF its as simple as twisting out and twisting in some bulbs like it was for the LS
I honestly can tell you, I am not all for this soldering and getting resistors and ETC that a lot of these other guys do to get super bright climate controls.
Im also not trying to change the LED's on the button controls either... just the back lighting...
Ive been wanting to know this for THE longest.
