'99 Gs300 - Gear indicator light
The gear indicator light on the shifter panel sometimes goes dark after I shift from Park. If I shift back into Park and then into Drive - the light comes back on. Has anyone else had this experience?
Can you post a pic of this im a lil confused you talking about the lights on the gauges where it tells you what gear your in because i have a 99 GS300 and i don't see any lights on the shifter panel
op, pull cluster out, check bulb, get a terminal cleaner and clean copper connections on back where bulb goes in, change bulb while your in there
um u STILL talking bout the shifter lights, they talking bout the lights on the cluster not the ones by the cupholder
just in case anyone wants to know how to change that one though...
post # 4
https://www.clublexus.com/forums/gs-...ator-bulb.html
post # 4
sergusha
03-31-04 07:33 AM
