GS430 Timing belt - which one?
The weird thing is that I see each of these specified for my car (and for all 4.0/4.3/4.7 motors for that matter) depending on which website I go to (Sewell, Carson, Pembroke). I am beginning to think that they are interchangable, or two part numbers for the same item (?).
Here it is....> the belt that I've replace was 13568-09070. I had also replace the lower joint also. The part numbers are: 43330-39535, and 43340-39415 with the Serpentine belt 90916-02586...I hadn't replace my water pump yet, which I should when I did the t/belt. I will do the water pump and thermostat and replace upper/lower hoses soon..
1356809070, 430, 4334039415, 9091602586, belt, gs, gs430, install, kit, lexus, number, part, pn, timing
