225/40/18 air pressure ?
^^ do not pump max tire press of the tire. that is stupid.
32psi is good for most cars. look at the drivers door jam and it will call for 30psi stock.
is the tire stretched? if it is, run like 10psi more than normal.
but 32 provides comfort and enough air pressure to get good mileage.
FYI if you inflate at max psi and it gets warmer due to weather/driving for one thing the ride quality will be worse but also u can damage the tire. 30-36 is fine, for best mpg do 36, best ride/handling do 30, im at about 33
