HELP recently bought a gs300 and got a problem already
bought a 2001 gs300..he seller told me he installed coilovers on the car so the ABS VSC lights went off and you can hear a constant beeping noise like a hard drive coming form the dash....i read on the forum its the vsc warning chime but i tried resetting the ECU but nothing happened...anyone know what the problem might be?
Master Thread Closer!!
Check how and where the ABS/brake lines are secured. Zip ties are a NO-NO. Should come with a bracket.
If secured too high onto the coilovers...or there's not enough slack....esp when you turn your wheels max left or max right...VSC/ABS light will come ON.
Good luck.
Good luck.
