02 sensors
10-27-09, 09:22 AM
02 sensors
i need both bank 1 sensor 1 and bank 1 sensor 2 o2's. where can i get these for the best price? also is this considered front upper and front lower?? cylinder 1-3?
10-27-09, 09:26 AM
it would be on the drivers side...both of them. Bank 1 sensor 1 is the top drivers before the cat and Bank 2 sensor 2 is after cat. I would not go with anything but the factory 02's. i've tried bosch ones and the ecu doesn't like them too much...
10-28-09, 07:39 AM
where is the best place to get them and what exactly would happen if I don't get the OEM ones
10-28-09, 07:48 AM
Do not go with a cheap aftermarket one. Plug and play only!
10-28-09, 07:49 AM
well it says that they are plug in play.
10-28-09, 07:49 AM
i got all of mine from NGK.com when i had my vehicle serviced with o2's. to me they had the best prices for aftermarket plugs.
i think he meant plug and play as some o2' require you to use your factory harness and require soldering of the wires.
10-28-09, 10:20 AM
10-28-09, 11:34 AM
oxygensensors.com
......I got all new denso sensors for $400 and some change with free shipping.
10-28-09, 12:28 PM
yup just ordered from oxygensensors.com
10-31-09, 12:54 AM
I go genuine, but sometimes they be having genuine toyota 02 on ebay. i purchase mines there.. but NGK is still a good brand.
11-02-09, 05:58 AM
Quote:
Originally Posted by
LudeNsoL
Damn! Got to this thread a little too late. I was going to suggest sparkplugs.com.
I got all 4 for under $300! brand new Denso w/connectors! I think the rears were around $68/ea and the fronts were around $82/ea.
11-02-09, 08:43 AM
wow thats alot cheaper then what i payed. but its okay thanks though
11-02-09, 10:55 AM
NELOC Moderator
How good is the products from oxygensensors.com?
I have the following check engine code (p0161) and they recommended
THIS Part #: 250-24244
I am a little hesitant as to go with an aftermarket brand on this
RichS11
Performance
02-07-15 09:34 AM
garylexus
11-22-14 04:10 PM
Deadpool88
06-27-14 10:39 PM
Matromony
Performance & Maintenance
02-27-14 03:43 PM
shboni
Performance
12-30-13 05:41 AM
