I'm at a loss
I'm at a loss
While driving my 98 gs400 today my brake warning light, VCS warning light, ABS warning light and the VCS off warning light came on all at the same time as well as a high pitched alarm sound came on and did not turn off. Can anybody tell me what might be the problem.
Check to see if your battery is connect properly..I had the same issue before where I'd stop at a light then all the dash light came on. Pop the hood and find out that the Fr*** battery cable came lose..
for the help
turns out the correct answer is that after checking the codes 3 times by the mechanic the abs system went bad. lucky me, they want a couple thousand for the part. any suggestions. thanks for all the replys.
That happen to me like 3 times when i first had my car. I switch a new fuse out and it went back to normal. check to see if your break light works as well? cause mine didn't.
TedFury
08-19-13 07:22 AM
313vip
09-19-07 09:00 PM
