How to install curtains!
each plastic hanger slides into the top and bottom rails. you have to manually slide these in. you then clip the hooks that are attached to the actual curtains to the according hangers. then you use the provided double slided tape to attach the top and bottom rails to the smooth black portion of the windows right inside the chrome trim. make sure you mount the rails (assuming you are mounting these on the rear windows) on the side closest to the front seat. i superglued in the plastic plugs that go in the end of the top and bottom rails to make sure the hooks don't slide past the rail. some peole have had problems with the top rail not sticking, so many use glue or bolt in the top rail. its pretty self-explanatory, you don't really need the directions. on yea, you have to mount the main large black plastic hook perpendicularly on the vertical inside part of the window so you can hook the main curtain wrap (with the Belleza logo and velco) around it in order to get the curtains to stay at the very corner of the window so it curtains don't slide around when driving.
hope this helps, i dont have any pics.
