Need help diagnosing a sound. 2000 GS300 114K
Old 11-17-09, 09:37 AM
gman44116
gman44116's Avatar
Default Need help diagnosing a sound. 2000 GS300 114K
I have noticed recently a sound when the engine is cold.
When I put the car in gear and as soon as I step on the gas pedal, just lightly I hear this light rattle sort of a droning sound. Let off the gas and it stops, step lightly again and I hear it.
If I jump on it I don't hear it..
It is related to the gas pedal and might be an exhaust issue???
When the car is warm I do not notice it. When cold, I can make the sound by stepping on the gas pedal gently. the sound only lasts a second or two. Only hear it when I first give it gas, more gas and it disappears.
Any advice??
Old 11-17-09, 09:59 AM
Debonair
iModerate
Debonair's Avatar
Detonation maybe? Any difference when in Neutral or Park?
Old 11-17-09, 10:03 AM
gman44116
gman44116's Avatar
Only makes the rattle/drone very briefly in Drive not N or P.
Old 11-18-09, 09:14 PM
gman44116
gman44116's Avatar
bump..............
Old 11-18-09, 09:54 PM
AshburnM3
AshburnM3's Avatar
exhaust heatshield?
Old 11-18-09, 10:06 PM
CPMD
CPMD's Avatar
Originally Posted by AshburnM3
exhaust heatshield?
I was thinking the same thing
Go to any shop they should take it off for not much
Old 11-19-09, 07:59 AM
gman44116
gman44116's Avatar
Isn't the shield there for a reason? If I take it off does that have an adverse affect on the exhaust system or the cars undercarriage?
Old 11-19-09, 09:17 AM
BP_VVt-i
BP_VVt-i's Avatar
yes it is there for a reason! if its a rattle sound n its coming from the center of the car or seems lyk its right under ur transmission then its probably the heat shield. jus jack ur car up n look at the mid-pipe up to the headers. if u car is cold then jus press on the plates of metal that surround ur exhaust. if they move then thats the problem. i had this problem n i jus got an exhaust clamp for mufflers n sum heat resistant rubber tubing n ghetto fixed that rattling sound. i havent had that problem in over 4 months. but thats if its a loose heat shield. only other thing i can think of is that its about that time to change the timing belt, and serpentine belt for ur car if u nvr changed it. GL
Old 11-19-09, 11:04 AM
gman44116
gman44116's Avatar
Did the T-belt and serpentine belt last week. thanks for the info. The sound is so slight only when cold and from a stand still to a slow start each time I tap the gas pedal. It's not a 'loud' rattle just sort of a annoying slight drone for a second each tap on the gas...
I'll check the heatshield out next week when its up in the air..
Old 11-19-09, 06:50 PM
BP_VVt-i
BP_VVt-i's Avatar
cool. keep us posted. it may jus b age revealing itself.
Old 11-20-09, 10:44 AM
sakataj
sakataj's Avatar
exhaust heatshield?
def sounds like a loose heatshield. think the gs300 is notorious for this from what i recall reading
try mike....he's on here as figs he makes a aftermarket heatshield.
jcdisciple
01-14-16 08:00 PM
satiger
GX - 1st Gen (2003-2009)
03-27-15 06:32 AM
calboy76
04-28-09 01:21 AM
Ace00
05-31-08 11:31 PM
SirSkrip
06-12-07 03:02 PM
Quick Reply: Need help diagnosing a sound. 2000 GS300 114K
