Help car blows alot of smoke!
OK ill start from the beginning so i was driving to upstate NY like a 2 hour drive from Queens NY i was going to my house and when i got there i noticed i had no more oil in my engine so i refilled it wit some oil i had around there that i use on my Honda cant remember what type it was so i can get back to the city so i got back and i change the oil to Castrol GTX 20W 50 so after changing the oil i notice my car smoking a lot so a week passes and oil dropped again so i put another quart now after 10 days no oil has been lost but a lot of smoke is still coming out when i turn it on a friend of mine told me the valve cover gasket might need to be changed and i noticed oil stains all on the right side of the engine also theirs oil stains around the timing belt cover and the bottom cover as well. idk what to do can it be that my engine aint good anymore or is there a leak somewhere i i have checked the oil pan but nothing drips Can someone pleas help
oil is the life line of your engine, i used 10w60 on my M3 and I thought that was crazy! 20w 50 is too thick for your engine unless you have a race car running at high temp all the time! winter is almost here and your thick oil in the engine is not going to be able to circulate FAST enough at morning/cold start up. heavy smoke from the exhaust could mean you have a blown head gasket or worn valve seals or worn piston rings. have a shop check it out asap. good luck
For an inline 6, I bet it's not as hard as a Mustang, but I bet it costs 3x as much.
I'm just hoping its not a head gasket if its a valve gasket i can change that myself but im hoping once i put synthetic oil back it wont smoke no more also the car runs fine no weird noise or anything so idk whats the prob
Yeah if its pushing alot of white smoke through the exhaust you defintely have coolant mixing with oil. If it was smoking from the engine you could just have a bad oil leak thats burning off on the engine of exhaust manifold.
You gotta take it to the shop asap!! It could get worse, And if its been pushed hard and overheated than you gotta also worry about the possibility of having warped heads which is a whole another level on expense!!
Quick rule of thumb though: White smoke from exhaust = Head Gasket ( coolant mixing with oil ). Bad piston rings or valve seals = Blue Grey smoke from exhaust!!
Good Luck with it man!!
