Extended Performance Mobil 1 thoughts
got an oil change today with the 15k or 1 year service period on this Mobil 1 full syn.
car runs extremely smooth and is a lot more quiet. noticeable difference. quiet on the rear end; not engine. I recommend.
got some torque masters on order as well. Star series.
and im finally going to get these 20" Spirits Vientrays put on. this will be the 5th set of shoes for this ride. and by far the nicest. x-)
![](http://www.vipstylecars.com/forums/image.php?u=5915&dateline=1213874893)
nice wheels brother...but i vote you take your OWN new pic of the spirits instead of recycling mine! considering i never really bothered to post pics of those things mounted up for the year i had them, it's only fair that you dont do it for me now that they're gone..hahaA. keep in touch with your progress kid. good luck.
So i've been using Mobil 1 Fully Sync oil and change it every 4k miles im I wasting my money? If so how long do you think I can go with it?
I know that my 2007 Mercedes C350 Sport can go like a whole year or 13k miles with Mobil 1 Fully Sync
i always wanted to use syst mobil 1 oil.... my car has 169k miles when the engine is cold is sounds good when it warms up it has a slight ticking sound ....i just changed the oil so i wonder if the mobil 1 would make the ticking sound stop... i heard that it will make the gasket leak or something becuase the motor is not used to it and old? can i go from regular castrol gtx 10-30 to full mobil synt oil? i really dont want any leaks so i just been playing it safe
help
my car has about 166k i am going to change my oil this weekend and i was wondering what would be better to use 5w 30 what i used before or 10w 30 i heard older engines should use the 10w 30 i need some experts in herei am going to buy my stuff in a couple of days
doesn't matter on the age of the motor. You could have 1,000,000 on it, and if you do not have blow by 5w30 is fine. If your piston rings are shot like they are on my Mustang, you can run 20w50 and it still won't make a difference.
I'd stick with 5w30 since that's what Lexus calls for. And unless you are running some high hp motor, the only gains in hp I have ever seen have been from Royal Purple and that was like 4-5 hp at the wheels.
I used Toyota Oil!!!!!change every 3k,and its fine lol but i add up a Anti-Friction Metal oil ,i forgot have many OZ need to add up every oil change but i have list have much for Diff Tranny and engine, i purchase 5 gallon bucket for 600$, BTW the engine works much smother after every oil change and the engines is quit as well!! plus saving the feature dameges of internals ,,,well thats how my engine had been servicing. i can post up pics of the special Oil i used??
