First time lexus owner, possible problem with steering wheel has free play/movement
Old 11-19-11, 09:41 AM
  #46
sakataj
sakataj's Avatar
Originally Posted by D-Boi
Figs needs to make some caster arm bushings so we can take a doodoo on tm engineerings websitr we robbig so many of us. Any idea how much figs' setup will cost?
he is in the works of some....
http://www.facebook.com/photo.php?fb...type=1&theater
cost for what setup?
Old 11-19-11, 10:15 AM
  #47
D-Boi
D-Boi's Avatar
For the control arm bushings.
Old 11-19-11, 11:49 AM
  #48
sakataj
sakataj's Avatar
LCA #1/2? UCA?
think these might be things you could ask mike about, i have no idea about costs or what he's making except what he posts on here or his facebook account
Old 07-29-13, 03:51 PM
  #49
YxUxMADDDD
YxUxMADDDD's Avatar
bumping info so it won't be forgotten
Old 07-29-13, 07:04 PM
  #50
dcz
dcz's Avatar
Picture doesn't show up about placement of zip tie... anyone have it by chance?
Old 10-22-13, 04:36 PM
  #51
DosyBoy
DosyBoy's Avatar
My 98 gs4 does not have the holes in the brackets.. I just zipped mine to that little latch right above it, steering feels firmer didn't take it on the highway yet....
Old 05-28-14, 10:17 AM
  #52
honasbone
honasbone's Avatar
Just did this on my 01 LS 430. It's tightening things up a bit. There is still some free play in the steering wheel, but not like before. Likely multiple things going on for me. But this seems to have gotten rid of the freeway speed vibes and noise I was getting. It was mild, but annoying for me. Especially since I'm on the freeway just about every day of the week.
Cheap and easy fix.
Old 06-08-16, 01:45 AM
  #53
BlKTC
BlKTC's Avatar
Bringing this up from the dead because I just did the "zip tie repair" I would say 80% of the vibrating went away!
Now, my new issue is, some of the vibrating has now transferred to the chassis. What do I do to get rid of the chassis vibration??
Car:
2000 GS300
Megan Coils
Megan UCA
Polyurethane Front Caster Bushings
Replaced LBJ
Replaced inner tie rod
Replace outer tie rod
New Brake rotors and pads
Balanced wheels and tires (tires are fairly new)
Motor mounts still seem to be very strong
Old 06-08-16, 06:24 AM
  #54
AmanO
AmanO's Avatar
This should be stickied.
Old 06-27-16, 09:21 AM
  #55
dchan
dchan's Avatar
I'm so glad I found this thread. I just did the zip tie fix a few days ago and the steering column noise is almost completely gone except maybe when hitting really big bumps, even then it's greatly muted.
Original problem: 2006 RX400h with 190,000 kms. Looseness and noise started around 160,000 kms and gradually gotten worse. With engine on, wiggle steering wheel back and forth an inch and you can hear knocking noise and also feel it in steering wheel. Occasionally going over bumps you can a chattering/knocking noise.
The Toyota dealer said I needed a new steering rack and suggested I replace the yoke too since they're already in there. $7000 CAD for the repair. Cars value is not worth spending that kind of money hence my search for alternate solution. I was able to isolate noise to inside cabin so did not think it was steering rack. This fix pretty much confirms it.
I did not remove any footwell covers and just felt around blindly to do it. Took about 20 minutes to install three 4.5mm wide zip ties. This is with my 2 year old in drivers seat stepping on my face and also nervously working under the knee airbag thinking it could go off; so it didn't take too long.
The cars handling is so much better now. A bit firmer too, might be combination of less play and friction of zip ties, but I don't mind it too much. I might try the bearing fix aijoju did, but does anyone know where to disconnect shaft to slide bearing onto?
Old 08-01-16, 10:46 AM
  #56
sakataj
sakataj's Avatar
Originally Posted by sakataj
bringing some duct straps home from work and will try this, this weekend
almost 5 years l8r and i finally installed
Old 08-01-16, 03:58 PM
  #57
azndriver
azndriver's Avatar
IMO what this looks to be steering wheel having free play which looks to be the steering shaft assembly itself (worn u joints)
now if there was a provide a more heavy duty u joints to support the weight of the complete steering wheel assembly (which is pretty heavy)
then the issue could be solved again IMO.
Basing this theory from a Toyota recall in regards to a defective steering shaft for popular models, like the camry, Rav4, Prius,
Old 08-02-16, 12:56 AM
  #58
Lutkis
Lutkis's Avatar
Is it normal to have to turn the steering wheel A LOT when turning? I mean the steering wheel is like a merry-go-round when I'm driving in the city.
I want to get it stiffer so that when I turn the wheel the effect is immediate. Now if I turn the steering wheel for example 90deg the car barely turns at all. Does it depend on the speed of the car 'cause I think it's a bit stiffer when I'm going faster?
With some of the cars I've driven if I turn the wheel 90deg It would most propably go offroad at that point..
Old 08-02-16, 06:43 AM
  #59
sakataj
sakataj's Avatar
i actually believe that the bushing coming into the car has play in it and thats what causes the "wobble" if not i think there is a bushing issue
Old 08-02-16, 11:46 AM
  #60
LexusK
LexusK's Avatar
Did you grease anything or just installed the zip ties? Saw somewhere that lithium grease was necessary.
Quick Reply: First time lexus owner, possible problem with steering wheel has free play/movement
