Gs300 vs gs400
Gs300 vs gs400
I have a question about these two cars. I know the GS3 has a 225hp V6 and the GS4 has a 300hp V8 but what else is diffrent between these two cars? Im about to go see a GS300 this weekend i am planing on getting because i couldn't find a good deal on a GS400. Can you guys help?
the gs300 have an i6 ,all gs400's have e shift only 2001-2006 gs300 have it, gs400 often have navigation and upgraded stereo and a few more options, and most 400's you will find have the spoiler, even though i dont like.
Forum Administrator
Please search this 2gs forum for gs300 gs400 difference and you'll get TONS of threads example below I pasted in from a previous writeup I did
Please try the search feature and you'll find a lot of the stuff you're asking (or may want to ask), no waiting. For example, I searched for the question "Should I get a GS400 or GS430?" using "gs400 gs430 difference" as keywords and found the following threads among others.
https://www.clublexus.com/forums/sho...430+difference
Should I get a GS300 or GS400?
https://www.clublexus.com/forums/gs-...-or-gs400.html
https://www.clublexus.com/forums/sho...ch+gs300+gs400
https://www.clublexus.com/forums/sho...d.php?t=149311
Should I get a GS300 or GS430?
https://www.clublexus.com/forums/sho...ch+gs300+gs430
What year is best
https://www.clublexus.com/forums/sho...threadid=15832
https://www.clublexus.com/forums/sho...threadid=83730
The GS Series has few problems as it ages. The earlier years (98/99) have more quirks then the later years, but both have been known to have:
Moisture in Healights
Low/rough Idle Issue
Door Actuator Problems
Dash Rattle
Sunroof Rattle
Vibration at Highway Speed in wheels
Wheel bearings
90k timing belt service needed
https://www.clublexus.com/forums/sho...400+Rough+Idle
https://www.clublexus.com/forums/sho...=Door+Actuator
https://www.clublexus.com/forums/sho...ht=Dash+Rattle
https://www.clublexus.com/forums/sho...Sunroof+Rattle
https://www.clublexus.com/forums/sho...GS400+low+idle
https://www.clublexus.com/forums/sho...light+Moisture
https://www.clublexus.com/forums/sho...s400+Vibration
Are there any technical service bulletins? TSBs
https://www.clublexus.com/forums/sho...&highlight=tsb
https://www.clublexus.com/forums/sho...threadid=28501
These links are a little dated, but still apply. There are many more threads (including more recent) if you care to search for them
What year is best
Dash Rattle
Sunroof Rattle
Wheel bearings
