TRD LSD from Toyota Supra
Old 05-06-02, 07:55 AM
Mariusz
Mariusz's Avatar
Default TRD LSD from Toyota Supra
Do any of you guys know the part number of the TRD LSD for the GS400? Is it the one from the NA or Twin Turbo Supra?
Old 05-06-02, 08:07 AM
///MDex
///MDex's Avatar
Have you tried reaching Steve Ganz? He could probably get it for you lickety-split.
+1 (800) 908-6968 ext 2381
gonzo4u@earthlink.net
HTH
Old 05-06-02, 08:11 AM
Mariusz
Mariusz's Avatar
Already tried, but he was not in. Figured I might get an answer before he calls me back
Old 05-06-02, 10:01 AM
GS430 GUY
GS430 GUY's Avatar
Mariusz,
The part # for the TRD LSD is 41301-JS401 That is the part # I have on my invoice from Steve when I got my TRD LSD.
Old 05-06-02, 10:20 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,235 Likes on 1,355 Posts
Marius,
The TRD LSD and the Supra (also sold as RMM) LSD are two different products.
The Supra is a Torsen-type LSD and has a 3.76 gear ratio. The
TRD LSD has a 2-way clutch type and still retains the stock 8" ring gearing.
I believe Steve G will tell you the TRD will handle more power, which will matter to you if you're putting that SC in! Might also help with hitting the rev limiter to keep your gearing stock/lower.
I found a site that lists the Supra NA LSD as 00647-41301-200 and the Supra Turbo LSD as 00647-41301-203.
Old 05-06-02, 11:06 AM
Mariusz
Mariusz's Avatar
Cool. Does the GS400 have the same LSD as the 430 though? Thanks.
Originally posted by DaveGS4
Marius,
Aprreciate the info.
Old 05-06-02, 11:59 AM
SADDLE
SADDLE's Avatar
what is an LSD, i have heard this term used a couple of times since i've been a member...
drew
Old 05-06-02, 02:23 PM
RacingAristo
Guest
Posts: n/a
limited slip differential. There were lots of discussion on this topic before. Try to do a search.
d1trainee
SC- 1st Gen (1992-2000)
09-13-10 02:34 AM
lsflame
Performance & Maintenance
06-01-06 12:37 PM
MongolKhan
15
10-18-04 05:31 PM
l7in6k
12-02-02 08:58 PM
Quick Reply: TRD LSD from Toyota Supra
