Gs300 wont start properly
Hey guys i have 2003 gs300 with about 84000 miles on it. ever since i bought this car i have this problem where the engine will keep cranking and not come on. then i have to continously turn the key and press the gas while the car is cranking for it to turn on. I replaced my throttle body spark plugs and alternator in the past and it seemed to have fixed the problem for a while. Now it is doing the same thing occasionaly especially when i park it in my parking structure at work under ground. i copied a link from another member that had the same problem.
http://www.youtube.com/watch?v=_fJvG6YLcbk
Please let me know if you have had the same problem or know the solution. Thanks in advance for your time
Try replacing the MAF sensor. I had really crappy performance, and the light never came on. At advance auto parts you can buy and try there. If it dosnt work, bring it back in and return it. If it does, its only $70.
Moderator - Electronics Forum
Fuel pump. The MAF has a dual element. If one of the elements goes bad, the other should take over and throw a code.
A bad starter will just "click" and not crank the car. If it's doing the same thing on the video, then it's cranking, but not providing enough fuel to the engine. Or any fuel.
What gas are you running? The cheaper brands of 93/92 octane took out my pump.
I always run premium from chevron or 76 but then again iono what the previous owner ran. No codes come up either and it only does it once in a while. the sound is exactly the same as in the video. so it could be both the fuel pump and maf?
hi guys, i replaced my fuel pump and it worked great for a couple of days but for some reason it did the same thing where it cranked and cranked but never fired up. i tried it again the next time n it fired up. i dunno what else to do? any i deas?
GSVIP300
03-07-14 04:47 PM
mbaker7
03-09-12 10:15 PM
