Need help ASAP Shorted something on Front Passenger!!!
12-02-09, 08:09 PM
found the problem thanks anyhow
12-02-09, 08:22 PM
You should check your fuses.
12-02-09, 08:25 PM
Check the fuse on the right kick panel on the passenger side. The fuse is 7.5 A. The name is ECU-B I think. GL.
12-02-09, 08:35 PM
Checked the fuses already
Gs4-fiend. I checked the fuse ecu-b its still good
Dara
12-02-09, 08:36 PM
check all fuses.
even engine bay ones
12-02-09, 09:09 PM
All the fuses seems good to me..... its not sensing my passenger door shut
12-02-09, 09:35 PM
Is there anything that has to do with the ecu box in the door panel? I checked all the fuses and under the hood already.
12-03-09, 10:11 AM
12-03-09, 11:24 AM
I have no idea if this will work, but try disconnecting your battery and leaving it disconnected for awhile- might as well try this. Hope this helps.
12-03-09, 07:44 PM
Quote:
Originally Posted by
DPromGS
So...what was the problem??
02-06-10, 01:29 PM
it happened to me before,its the ecu box on the door. when you unpug all the connectios to that ecu. it will stop but you wont be able to roll down your glass and all that stuff
Gs3500
04-03-17 08:17 PM
wallaceb
05-07-13 11:58 PM
chloe
09-08-12 02:36 PM
APScott
08-06-11 05:44 AM
jbbnet
02-29-04 07:56 PM
