HID Light bulb change
I recently changed my HID light bulb and how they are both firing really high. The beam is shooting at the trees. Did I install it wrong or do you have to adjust the headlamp everytime you change the bulb?
I think I installed it right, the ground wire on the bulb us facing downward just like the stock bulb. I also aligned the bulb with the grove inside the headlight, so I think its good.
I found the grove on the Xenon bulb to be slightly narrower, so when it was installed it was slightly tilted. I went ahead and cut it slightly wider, so I think its fixed now. It should be properly seated. I'll find out tonight when I take it out. Thanks for the help EMOSHUN.
xmike714x
07-28-11 12:14 PM
TXES350
ES - 5th Gen (2007-2012)
03-12-11 07:46 PM
Lilflip#2
03-27-09 05:22 AM
